Does this look tacky
-Dan-
Hi guys what you opinion on this rear number plate light I made, got fed up with mine deciding when it wants to work and it went all cloudy, I'm not sure about it, kind if like it though it's different
There not expensive about 7 or 8£ as you say, it's just a track car really but need it to be road legal to drive to the track so looks ain't massively important, just like trying to make things before buying a new part im weird like that!
Mine was intermittent too so I disconnected it and files down the two prong terminals as they had a layer of awful on them. Worked perfectly afterwards!
Also wet sanded the plastic and it came up really well. Just a heads up in case you decide to go back to standard matey.
cheers bud :) that's what I had to do with the rear tail lights!
I replaced mine because it was dirty and full of grime etc. new one took about 2 weeks to look exactly the same :(
Mine broke so I spent £7 on a new one, that then broke so I just left it. When a car is following with lights on at night they will see it, it doesn't really need to work.
Seriously?
I had to re-read the OP text twice to realise what you were on about. Stood 10ft from the car and gun to my head, I'm pretty sure I would have NEVER seen that after 30+ attempts!
For the record, it look ok - but the standard one is better.
D.
Why is there a gun to your head in this scenario?
Because huge bodykits, unusual wheels, lairy decals would stand out a mile and could be discussed as tacky or not. If my life depended on it - I couldn't tell you what would have changed on the car the OP mentioned - the change was that small.
That's what I was getting at.
D.
