i found a set of OZ f1's, they are 4 stud pattern but the bore diameter is 66mm, will this still fit? or do i need to find out the distance between opposite bolt holes?
the bore on nearly all clios is 60mm ur bolt holes will b about 100mm between opposite bolt holes, if the bolt holes match all ull need is sum kind of plate that makes up the 6mm difference.
will fit providing the stud pattern is 4x100, you'll need sprigot rings to match the bore up to the hub otherwise you'll have a whole load of pressure on your wheels bolts
