Dogbone mount fitting question
After some help please.
I'm replacing the above on the 182. Got the old one off no problem. However when trying to fit the new one I can't get the bolts to line up. Looks like the bottom of the engine needs to move back 2 or 3mm.
Is their a trick I should know?
  172 cup
its designed to do that when you take dogbone mount off the engine tilts back :) when you re fit it and your sat there scratching your head its cuz when you yank on it and pull it together that pulls the manifold up and out the way of the subframe ;)
Matty
