dont sart clio
Car  clio
Hi my 1.2 8v s reg wont sart once it warm or been on a run. can it be that cut fuel cut off thing near battery ,it sounds like the battery is flat when u turn the key . B ut once car have been standing 4 awhile cold its ok , hopes this makes sence thanx kirstie
Check the battery voltage but if the starter isn't running fast enough sounds like a bettery issue
If the battery is good check the temp sensor
Thanks edde chage starter new batt were abouts is the temp sensor pls or is this on the block somewere many thanx
