Door Cards
How do you take these off? How are they held on? Do they just pull off with a bit of firm force, or is there a special way?
Cheers, Tim
what car is it on?
My valver you need to unscrew the bottom pocket pannel bit (needs star shaped screw driver) once that panel is off then you need to unscrew and remove the door handel and then the door car just clips off. There is some sort of stringy glue used as well to hold the card on so its a bit messy and annoying.
Kev
What about the back ones?
Its a Ph2 Valver, Ive found a crashed one, gonna be having the interior, was gonna take the door cards too...
Then a decision, keep the Ph1 interior, or put the Ph2 one in... not sure which to have!
Tim
Cant remember but when i swapped mine for the leather trim i found the front door cards harder than any other part. The back ones took bout 5 mins each.
Cheers mate!
I imagine once Ive got the door inside door handle bit off, its just a case of pulling it off. If it ends up been too much hasstle Ill just leave them in I think....
Tim
