swapping my dented door with a good one tomorrow, am i right in thinking its 1 torx bit for the strap, then 1 pin top and bottom? Is it as easy as i sounds?
Yup. Undo the check strap, unclip the loom harness (the black clip pushes up, then the plug pulls out). Remove the clips on the pins and knock out. Have someone to hold the door though!
I dont think you can adjust the gap from the door to front wing....... The latch pin can be adjusted for how the door sits when shut to the rear quarter...
