door trim
Car  clio sport 182
the trimming down the outside of my door is ratling from speaker bass,how do you remove them,is it a case of just pulling away or do they slide and pull etc
the piece on the door has one screw open the door and it is just on the other side. pop the rubber stopper off unscrew then slide the hole thing towards the back of the car. the other little bit just slides off too towards the front of the car. you may be missing some clips if they are rattling so a trip down to renault probaly but i think there like 70p each!
Hate to sound as thick as pigswill but where on earth is this screw??? Ive taken off the rubber lug but theres no screw underneath that, just one of the clips thats visible..??
on mine you pull out the rubber bung and there is a torx screw behind it. mines a ph1. not certain but i think ph2s have a plastic clip which you have to push then slide the trim towards the back of the car at the same time. it is in the guides section i think! if you prise it off with a screwdriver you will rish breaking all the other clips on the trim which you will have to buy new ones from renault. hope this helps!
