Yeah same.I've used mine to cut through all sorts.
With the right disc they are actually pretty good.
What sort of discs did you get? Theres plenty of chinese stuff on ebay I cant tell whats the decent ones
Agree, they are such a useful tool to have. I've had mine about 20 years and apart from a couple of bushes it's been fine and taken a lot of abuse. I use mine all the time for cutting , sanding and grinding.I've used mine to cut through all sorts.
Why are you using a dremel to cut your bush?Agree, they are such a useful tool to have. I've had mine about 20 years and apart from a couple of bushes it's been fine and taken a lot of abuse. I use mine all the time for cutting , sanding and grinding.
Couldn't afford a shaver at the timeWhy are you using a dremel to cut your bush?
