The circlip on my nearside driveshaft where it joins the gearbox has decided to slip out again causing the problem of no drive.
I replaced the parts with new Renault items when it did it a couple of months back.
I am looking for a definitive solution for this now and if what I have read is correct the options available are:
- Spot weld it in
- Drill some holes and bolt it in
- Buy the Renfort part off eBay and fit that
- Buy 182 gearbox as I understand they are bolt in type as standard
I don't really want to go for the last option due to expense and also that I won't know the condition of the gearbox. Also can't really be bothered with the hassle.
With regards to modifying the existing setup what is the most effective option?
- Spot weld it in
