Driveshaft problem
  clio 172
Hi All,
I've just changed the discs and pads on my 172 (2002) and have noticed that there is a split in the inner cv gaiter on the drivers side. I was wondering how easy it is to change this gaiter or if it can be changed?
I'd appreciate any help with this.
Thank you
David
  RB 182 & Lotus Evora
Do you mean the outer cv joint? Right next to the wheel hub? if so you can get a split boot kit, which ive NEVER had a problem with in the past. They are very easy and very durable ;) The inner boot...yeah laura is right, shaft will need to be pulled out and then replaced.
