Dry ABS Pump
Car  182, SQ7, Trafic
All brake fluid from car has gone, new master cylinder is going on, possibly new lines too. I've heard its a bit difficult to get the fluid back into the ABS system?
Very hard to get the abs pump filled and bled without the renault diagnostic gear, only way you'll be able to do it is to fill and bleed as normal then drive it (not far) and get the abs to operate. It'll go spongy as feck and then rebleed it, then rinse and repeat until its clear.
And even then it may not get it all out so you might end up having to find someone with a clip to bleed it.
Try cracking the unions off on the abs pump and bled until fluid comes through there. Also do it with the ignition on. Havent had an abs pump hard to bleed through though.
