Dual throttle tracks?
  Beaten up 182
Just been looking through the service manual and the wiring diagram shows a supply and earth feed from the injection computer (pins 74, 75) and the signal input (43) but the fault on mine is a difference between the two tracks? Did they change the design?
  182/RS2/ Turbo/Mk1
Ph1 has 1 cause its mechanical, ph2 has two like Dan says because on an ETB car they cant risk opening the throttle when you have asked not to.
