DVD headunit fitting help..?
Car  E36 Coupe & Mk4 Golf
I bought a dvd headunit last night i have fitted it however when i come to connect the aerial wire for the radio they are different.
Some one has cut the plug off the headunit and used a bullet connector, can i cut the end of the aerial wire and put a connector on it?
Thanks Mike
Usually the aerial from your car plugs directly into the headunit, seperate from the other wiring loom with all the wires in it.
Is there not a hole you can plug your car's aerial wire into (you may need the adaptor above), rather than connecting it to a wire in the loom?
Nope, where you normally plug the aerial into thats been butchered with a bullet connector but the aerial wire on the loom is all intact
