If i change original ECU on Clio (2002) with aftermarket ECU, what about air bags etc that are controled by ECU? Must i leave my original ECU plugged, or there is some separate computer that is controling air bags...?
Well not a aftermarket ECU like Autronic or Motec. We don't have customer support for that products here anyway.
I will probably use customized I.A.W. WEBER MARELLI. Its a progamable engine management system that controls both fuel and ignition, it also controls the idle valve, boost solenoid...
