It's either 20 minutes if the ECU cover comes off or several hours if it doesn't.
Last time I did it I took the ecu bracket off whole and lightly tapped the cover out.
Everything else is easy, UCH has a clip which goes over the dash frame which you should be able to see on the replacement.
Decoder ring and key fob are easy.
I've got the ecu cover off already just couldn't figure out on removing the ecu, do I need to remove the battery and induction pipe for access? Hoping it goes smoothly but with my luck it won't haha
