Ecu - uch swap
Sj1782
  Audi s3 8p
I'll be swapping my ecu and uch over either tomorrow or Wednesday anything to look out for when doing this? Is there a couple of hours work involved?
GrahamS
  335d
It's either 20 minutes if the ECU cover comes off or several hours if it doesn't.
Last time I did it I took the ecu bracket off whole and lightly tapped the cover out.
Everything else is easy, UCH has a clip which goes over the dash frame which you should be able to see on the replacement.
Decoder ring and key fob are easy.
Sj1782
  Audi s3 8p
I've got the ecu cover off already just couldn't figure out on removing the ecu, do I need to remove the battery and induction pipe for access? Hoping it goes smoothly but with my luck it won't haha
