Eibach 25mm Spacers on the front, won't bolt up properly. (172 Cup)
adamlstr
I just tried installing 25mm spacers on my 172 cup, the rears went on with no issues.
On the front, the bolts that secure the spacer to the hub wouldn't tighten up properly.
Looking at the back of the hub, the bolts wouldn't go through completely - they would only fit flush with the back of the hub. I didn't want to put too much force into the bolts as it took me long enough to get the seized wheel bolts off in the first place.
It wasn't just one bolt on one side, it was all 8 bolts on the front axle. Are Eibach 25mm's installable on the front axle, do the hub threads just need cleaning up? On the rear the bolts stuck out of the back by a good few threads.
​TIA
