electirc window fault
Car  clio 172
thank you for looking
on the drivers side, the window will not go down.
changed the fuse with no luck, but i can hear a relay clicking near the fuse box when i try and open the window any help will be great ;)
Motor will be knackered or the cable is frayed and jammed on the pulley. Both have happened to me and both have resulted in a new mechanism.
thaank you for your replay whats odd about his is some times the window works ok but sometimes not may be a lose connection with some luck but you proberly right knowing my luck lol
