renault clio 1.2 16v
OK after the electric light issue problem came on again I checked for a fault code. ( None recorded as no check engine light )
I then checked for possible vacuum leaks and all that was fine.
I have already swapped out the cranckshaft sensor, a new coil pack and replaced spark plugs due to the issue mentioned in the title. I have also used redex and carb cleaner but still got the light coming on.
I then jumped in the car and put my foot down on the throttle and got a rar rar rar up and down as I was applying my foot to the pedal and holding it on rev.
When the light finally went off I checked it again and I got a steady rev only real issue there was a laps as I initially pressed the pedal so now it's seeming more than likely that its a throttle issue maybe the throttle itself or an electrical issue going to it.
Any thoughts as I'm going to take it in tho the garage to go on test which hopefully confirms my suspicions.
Cheers Bill
Cheers Bill
