Electric Window not working - troubleshooting
Car  Megane cabriolet '06
Howdy folks, just looking for some help on trouble shooting an electric window on a Megane cabriolet Mk2 model.
The drivers window doesn't open or close at all.
I tested the 6 wire's going into the drivers and passenger switch on the drivers console,
Grey = 12v constant; goes to 0v when Passenger window goes down.
Orange = 12v constant; goes to 0v when Passenger window goes up.
Yellow = 12v constant. (Nothing happens when I press the drivers switch up or down.)
Black / Grey = 12v constant. (Nothing happens when I press drivers switch up or down.
Black = I assume is an earth.
Black = I assume an earth.
Am I correct in guessing that the Yellow wire and the Black / Grey wire should go to ground when the Drivers switch is pressed either up or down?
And am I correct in assuming both black wires are earths?
Appreciate any help.
I know it's not a Clio, but I'd imagine the wiring and switches are similar. Anyone got some opinion on my guessing the Yellow and black / grey wire should go from 12v to 0v when drivers switch pressed up or down.
Also, how would I bypass the switch at the loom connector to apply voltage directly to the wiring in the connector block, just to test the window works without the switch? Which wires do I bridge?
