Electric window wires got chavelled up in regulator
Car  ph1 172 Black
Ph1 172 2001
I done plenty of searching and even though the window was working and the motor works I think I need a new one.
The regulator had come un bolted from the door. Was a rattle in door so I took it to bits. Window used to go clank half way down. Anyway bolted it back on and my mate fiddled with one of the cables and then it went clunk and sounded like something broke.
Anyway I'm after a new one. Mine has a little yellow clip that goes thru window and up and down. Been looking at ebay and not sure which one I should by or to just get one from GSF or Eurocarparts.
What do people who know what there doing think of these (I'm not great at this sort of thing.) My wires got kinked cause they came off the channels.
Tried ClioSpares but they have't rung me back yet.
Looks same as mine but only upto 1998.
http://cgi.ebay.co.uk/RENAULT-CLIO-...14&_trkparms=72:1301|66:2|65:12|39:1|240:1318
This one looks same as mine but wrong side
http://cgi.ebay.co.uk/CLIO-MK3-N-S-...14&_trkparms=72:1301|66:2|65:12|39:1|240:1318
These look different but could I get them to work?
http://cgi.ebay.co.uk/Renault-Clio-...14&_trkparms=72:1301|66:2|65:12|39:1|240:1318
Or wire kit?
http://cgi.ebay.co.uk/SCENIC-MEGANE...14&_trkparms=72:1301|66:2|65:12|39:1|240:1318
Hi mate, we Have them In stock, there are a few different plugs/types depending on year, sorry we haven't rung you back yet you would probably have been getting a call tomorrow. They are 40 + Delivery and carry a 3 month warranty. All payment methods accepted.
thanks
Edit: we were asked to retail the wire kits for a company, the samples i received i tried on a couple of damaged regulators, they are terrible at best.
Oh brill. Thats sound ok price. It's a two pin plug to the regulator if that helps?!? It's a ph1 one anyway so that should help. Don't suppose you found the door handles too?
Ok any help anyone. Rang Cliospares and they said £50 and wouldn't post and thats no good to me. Tried GSF and they said £75 and I can collect or I can get one off ebay. Was hoping to spend around £50 to be fair.
I mean I'm not tight but it's Christmas and kids need feeding lol
Mine broke last week and renault wanted £204 as they do not supply the plastic bits that had broken on mine only the whole mechanism!
So i went to the scrappy and bought a manual winder mechanism off a clio stripped it down swapped all my bits over and all fixed for £15! i'd check what parts are broken as mine was quite easy to fix, just depends if you want the hassle of stripping a few clios down in a scrapyard to find the right bits ;)
Mine is 2000 Phase 1 the one on this auction is the one on mine,
http://cgi.ebay.co.uk/CLIO-MK3-N-S-ELECTRIC-WINDOW-REGULATOR-GENUINE-SALVAGE_W0QQitemZ370115431253QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item370115431253&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
I found that the plastic white guide at the top had broken of the metal support/runner had broke along with the plastic yellow coloured runner that the cables hook into - so i just replaced these off a manual mechanism as i couldn't find any electric window mechanisms local to me - as for the kinks in the cable i should think these be ok and dissapear once all tensioned up. The mechanism is a doddle to get out so i'd whip it out and have a proper look.
I have taken it out and the cable is a bit of a mess. The yellow clip has about had it. Mine is offside too.
Found a someone local breaking a 2000 Clio Alize but it's a 5 door not 3. Would this still fit?
Hi na u need a three door clio if u ring round u will find a breakers that will send it to u just make sure that is an exact match window regulator to urs and keep ur original motor on ur clio just change the rest if need any tips just say.;)
