electric window wires mk2 ph1.. HELP
CLIO-Si
Car  1.6Si + 182
i put my window down the other day and it clicked when nearly down since then the wires havent been on the coil and i cant seem to build it back up working..
ive wrapped the wire round from both ends of the coil and had it tight when back in position..fixed it with the 3 nuts then it doesnt use the tightness to operate the window..it always finds slack and just goes into spagetti..
currently got 2 big black bags over window and im stuck!!
next try will be popping of passengers door card to inspect how the motor on that side looks
just wondering if any1 else has had this problem atall??
