ELECTRICAL PROBLEM
  clio 172
HI ALL,
PLEASE HELP IF YOU CAN I HAVE A CLIO 172 2001 MODEL, I HAVE AN ISSUE WITH AN ELECTRICAL FAULT I THINK AS WHEN START MY CAR AND SWITCH ON THE HEATERS OR SOMETHING ELECTRICAL I GET MY BATTERY LIGHT FLASHING FAINTLY, I HAVE HAD THE ALTERNATOR AND BATTERY CHECKED AND THEY ARE PERFECTLY FINE, ALSO WITH THE SAME PROBLEM MY CAR CUTS OUT SOMETIMES WHEN COMING OFF THE ACCELARATOR PRETTY DODGY WHEN GOING ROUND A ROUNDABOUT WHEN IT CUTS OUT THE STEERING GOES HEAVY LOL NOT GOOD.
SO GUYS ANY IDEAS WOULD BE MUCH APPRECIATED THANKS ;)
Sounds like you may have a bad earth check the earth lead on the battery terminal then follow it down to inner wing 13mm spanner required loosen clean then copper grease also clean battery terminals & copper grease.
there is another one if you go in the n/s wheel arch wheel off the is an earth strap bolted on the under side across to gear box again take off clean with emery then copper grease.
Hope this helps.
