on a couple of cars i've had you can do the 'paperclip test' where you join two terminals in the fault code plug and the eml light flashes a series of codes to indicate the fault.
there's not enough detail with that method. with vauxhalls the eml light will flash a sequence that gives you a four digit code, allowing you to identify the problem sensor and even the type of failure, example:
