MATT BLACK said:
Thing is the red top is a vauxhall lump and fitsnice and smug in the corsa hole. Ive had to cut my n/s chassis leg out and strengthen the surround just so the n/s shaft will fit. There is a constant wobble as your driving in a straight line.
Yeh i totally understand that matt im just giving an example of high powered engines in the wrong chassis without torque steer.
Thought about RWD ??
Get a ford type 9 box, bellhousing made up, can use the sierra diff unit with different ratios!
Wouldnt be a total ballache, lots of fabricating parts and cutting out a tunnel for the propshaft, cut rear end out and spaceframe part for the diff to sit on! Use sierra rear hubs so the shafts fit straight in!
Would be a great project, lots of thinking!!
