frayz
Depends how much higher the cr is I guess, if it was half a point higher and the engine wasn't beyond msb I could believe 10hp ish. However agree that 10hp can be found by moving the air temp probe.
Cool job, by robotic you mean the cars and dyno are being controlled?
I've always wanted to integrate a a flyby wire throttle with a dyno (im sure people do it) and create some mad AI mapping system - could calibrate an ecu 10x faster and more safely than mere mortal!
The dyno is set with road load data for the specific vehicle and the robots will then drive the vehicle according to whatever drive cycle we wish. The headwind fan matches the road speed and the coast down times and loads are set to match.
Means we can simulate 1000s of km through city cycles or anything in between.
Sounds fun, I assure you it isn’t
