Engine Coolant level
GR7
  Shiny red R32
Has anyone ever had any problems with their coolant? (or whatever it is called) Mine was quite low a couple of weeks ago and I had two gaskets replaced. After driving about eighty miles the following week, I checked it after the car had been sitting for two days and the level had dropped to about half an inch above the lowest level. Where did the rest go?
Has anyone ever had any problems in this dept?
I tried doing a search but this facility rarely ever works for me and just got timed out!
Rich-D
  E90 LCI 330d
Loss of coolant is either a leak in the system somwhere (check pipes & for drips under car), or the radiator is gone/going, and if it aint either of them then the head gasket is the only other thing it could be...
However, in your case it might just be that the level has now dropped to replace air that was in the system after the gaskets were replaced (what were these?!), so Id top it up now and keep an eye on the level to see if it stays or drops!
GR7
  Shiny red R32
Ill try to find out what these gaskets were that were replaced.
You should be able to see where the coolant has leaked as when it dries it leaves white marks.
On my car (only a 1.4 not a 2.0) my coolant was leaking from a porous thermostat housing - took 4 visits to the dealer to find/fix it.
GR7
  Shiny red R32
Quote: Originally posted by BRUN on 18 April 2004
Firstly get it topped up
what gaskets were replaced ?
I think they were at the side of the cylinder head or somewhere in that area :confused:
  172 cup,s2 rs turbo
just the gaskets or the thermostat housing as well. Never known just the gasket to leak but ive had the thermostat housings becoming distorted before and causing a leak.
GR7
  Shiny red R32
Just the two gaskets were changed and I think they were at the side of the cylinder head (?). I will check the level again when I go out this afternoon.
Does the level vary depending on whether the car has been driven or left standing for a day or two please Jay?
  Mr2 Roadster
Up to 1 or 2...
If the lid is leaking it will rise up futher. Like when you open loosen it off when it is hot. *** Never do this, I got put in hospital loosening the bottle years back***
GR7
  Shiny red R32
Just been out and driven about four miles and checked the level when I got home and it is just above the maximum level now. So does that mean that it is OK now, or would it have taken longer than from Saturday until now for the level to drop?
I dont like to bother the garage if I can get the answers here! :)
Thanks guys!
  172 cup,s2 rs turbo
Your level will change compared to when the engine is hot or cold. I would keep an eye on it and if the level doesnt drop a lot and stay low then its ok. The level will change with engine temp so you could have a look at the level in the morning when the engine is cold. If after youve checked it when cold a few times and the level doesnt appear to drop then its ok.
GR7
  Shiny red R32
Thanks Jay Ill check it in the morning. :)
PS: Your typing is much easier on the eye today!! ;)
