Engine coolant
Car  Clio 182 cup
Right I had my radiator changed cause started to leak, I done it myself cause let's be honest it ain't hard.
So got it all changed over and all the pipes back on and started to fill the coolant bottle up took the bleed screw out and it filled up ok let it run for a while and then took the screw out again and it pi**ed out with water and no air which is good...
But the temp needle seems to be sitting higher than before ?
Is there anything that can be done or does this mean there is still air in the pipes ?
Well wasn't sure thought it sat just below half before but its only a slight fraction over half
Is it worth worrying about or is it better to let it all just bleed out and see if theirs any air in the pipes ?
if the needle doesn't get to above half, your car isn't warming up enough
I'd say you've fixed an airlock issue while you were changing the rad and now it's better than before. You'll likely notice better economy too.
Sweet well yet to find out wot economy will be,
Thanks for the advice tho.
So u think that it's better being just above half ?
