Engine information
  Clio 172 Ph1
I need some info about 1.4 16v, K4J (2002) engine.
What is the number of trigger teeth on flywhee? How many teeths are missing?
Is it the same as Clio 172?
I think its the same as the 172 which is 60 with 2 missing teeth I'll have a look tomorrow if I get a chance.
  Clio 172 Ph1
And how many teeths are missing on k4j?
I don't want to replace 172 flywheel with k4j flywheel, i just need info about k4j flywheel info because i will change ECU on my 1.4 16v so need to know which ignition trigger patter it uses?
