engine light at 80mph 172 cup
hey people new to the forum and only got the car on tuesday
as title says my engine management light came on bout thurs so took it for diagnostic which came up with errors
fan speed 2
missfire causing cat damage intermittent
cleared the fault started ran tested again no fault
so yesterday seen as the car had been stood by previous owner since feb , i changed the oil and filter took the spark plugs out an wire brushed any deposits off as apparently it had new leads plugs an coil pack bout 6 month ago
took her out all was fine
cruising today but when it reaches 80mph in 5th engine management light starts flashing
any ideas where to go from here as im totally new to renaults used to own vws
thanks in advance
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
The flashing MIL means you have a level 2 fault... not a perm fault but one that can damage the life of the CAT.
Most probably due to a missfire so the usual culprits to suspect; HO2, CTS, ATS, Plugs, Coil
thanks for the replys there ngk plugs in it,
yes mick the diagnostic came up with a intermittent missfire im just stumped to what it might be as it only seems to miss at top revs car seems to be running fine temp on display bang on half way getting good mpg its had new coil pack new leads just serviced
no lambda fault came up on diagnostic when the light was perm on just missfire was logged and fan speed 2
well cars been running fine since i changed the plugs an put some slick 50 through it then today on motorway put foot down an it flashed a lil an then went an didnt come back feels a bit hesitant like its not at full power then othertimes its fine any ideas guys
mpg is fine temp on display bang on half way could it be an air flow sensor?? ive just noticed sum1 has drilled the bottom of the air box aswell :S
