Engine light
Car  Mk1 16v brooklands
Ok so after last night (car conking out and not staring) the car now starts. and idles ok as soon as you give it any revs its revs up fine but wont idle properly (splutters) again, or it just cuts out, restart it and its ok on odle and does the same again. Engine light is flashing
Help please
just realised it was you that called. I could hear you but you couldn't hear me. New work phone badly needed.
flashing engine light is usually a "destructive misfire" fault, so it's dropped a cylinder. this could be the coil, a sparkplug, or an injector. Diagnostic plug in needed, guessing wont fix it sadly
Haha no worries dan, didnt realise you was busy today
The codes that came up were 0351 and 0352 ignition coils 1+2 :(
Fit a new set of spark plugs. If this doesn't cure it then it's likely to be one or more injectors playing up.
