Engine management light
  clio 182 ff cup
The engine light came on a few days ago while one piston stopped working. Managed to get it diagnosed and the report showed that the fuel injectors were faulty. So anyway, I took them off and replaced them all as they were really corroded. On fire up, the engine is running perfectly and drives like a stung rat. But, the engine management light is still on though the car is driving well. Will the light go off eventually or could this indicate another problem? I'm thinking at least this could be a post cat lambda....
Any thoughts?
  dan's cast offs.
you'll probably find it's bringing up lambda fault but this could just be from having a misfire, seen this a fair few times.
