realnumber 1
Recently my engine started knocking/vibrating really badly under acceleration in 1st and 2nd and also over bumpy surfaces in 3rd.
Turned out the mount on the drivers side had slipped right back (probably due to the shite road surfaces round here). I pulled it back and it's just about fixed it but if accelerating hard in 2nd up hills it still does it ever so slightly.
So the question is. Can the mount under the battery be pulled forward in a similar way? I'd think it would only need to be a couple of mm.
The mounts are all relatively new (1 year or so) and it has a powerflex dogbone so they should be all okay.
