would the drivers side engine mount cause a vibration in 3rd 4th and 5th are there oil filled
C col72 clio dci Oct 30, 2009 #1 would the drivers side engine mount cause a vibration in 3rd 4th and 5th are there oil filled
Budgie 330i. E30 Touring. Oct 30, 2009 #2 Very good description. Elaborate please. What sort of vibration? When pushing hard?
Budgie 330i. E30 Touring. Oct 30, 2009 #4 How low revs? Definitely not just as you go over a certain speed, which i think is more likely. Is the vibration rhythmic? Does it increase with speed?
C col72 clio dci Oct 30, 2009 #5 just revs when you go faster it goes off or you change gear at high revs its more when the engine is labouring
Budgie 330i. E30 Touring. Oct 30, 2009 #6 Duncan Bannatyne said: Because of your lack of punctuation and clarity, I'm oot. Click to expand... Me too.
Jonny1*2 Golf GTD Mk7 Oct 30, 2009 #7 i'm confused too, when is it knocking? is it both when you apply and remove your foot from the accelerator?
