engine mounts symptoms.
Car  172 MoNaCo.....
for a while now my exhaust has been knocking on the subframe, also when excelerating hard in 1st gear it makes a knocking noise.:(
basically are these both symptoms of failing/failed engine mounts?
iv looked into the uprated k-tec engine mounts, would it be worth buying the full mount kit or just replace the one topmount?:S
any help would be great,
thanks.
Go for the lower dogbone first (powerflex), it's cheap and easy, most specialists on here can do it in half an hour, price should be £60-70. Mine had started knocking every now and again, it doesn't now the powerflex dogbone is done. Gearbox feels much much better too!
im sure when i bought the car last year the guy mentioned he had the dogbone mount replaced. if thats the case what other do i change? just the two tops isit?
sorry to sound dull about all this just trying to save money!:)
