Engine noise
  Monaco 172
Just a question about the intake manifold,top half. When the cars warmed up it starts making a right noise, rattling away. Its definitely not the dephaser and I doubt its anything to do with the cams. Just want to know if this is common with the f4r or if there is a problem.
  Monaco 172
Also runs lumpy until properly warmed up, I hear a remap can sort this out. Any info on this would be a great help.
Cheers Dom
  Monaco 172
I know it sounds daft me saying the inlet makes a noise but that's honestly where it comes from. I'm bewildered as to how it would make a noise as its basically just an empty chamber with the air passing through it lol.
  Monaco 172
dephaser then
Yeah it is, pulled it apart again today and the dephasers worsened basically over night. Belt kit and dephaser now ordered. I have to timing kit for the f4r but never changed the dephaser, is there a special tool?
  A special one.
Only the tool to lock the cam pulleys, un do the pulley cap then un do the nut and the dephaser comes off.
Make sure that the end of the cam and the new dephaser are 100% clean and oil free, i would also replace the cam oil seals and also use all new fixings.
Renault sell a kit which has the nuts and seals in and replace the crank pulley bolt.
  Monaco 172
Thank you for that, I'll give renault a ring first thing tomorrow for that kit. Hopefully the car will be sorted by next week
  A special one.
Its not expensive, i think the fixing kit with the seals is about £25 and the crank bolt is about £7 if i remember right.
Renault do state that when replacing the cam belt kit these parts must also be replaced.
