engine not running right
Car  1.2 billabong
Hi all
Today i did a service on my car and noticed i had oilbehind my filter so i thought i would replace the rocker cover gasket after i had it all back together started it up and now it sort of runs but trys to stall it seems to be sucking air from a hole at the top back right of engine asif there should be a pipe on it but i dont have a pipe left or hanging from anywhere to put there so would like to know if anyone has something on there or any ideas what it would be
Plus i now have a clicking fron below drivers side headlight and also dont seem to have any brakes
Please help mike
Sound like you've not connected the brake vac pipe back up, or you've connected it to the wrong place.
All pipes are connected its a decent size pipe around 25 mm so i should miss it lol
Thanks for reply would the brake vac pipe be this big or would it bw a smaller one thatci have already fitted
Afraid I've no idea on the 1.2. From the symptoms you described though ( no brakes! ) it does sound likely.
