Engine Oil?
  Black Gold with cup packs
Bought my car from main dealer so not sure if fully synthetic oil was used? anyway to tell or is it best to just get an oil change its only £23 after all. What oil should I use? Elf?
£23 oil changes often use cheap oil so suply your own unless there using good oil and just getting it very cheap as they often do.
Changed my oil and filter on my 182 on Friday i used Silkoline pro s 5w 40 5 litre will be enough but will leave you none to top up with if needed later,think opie oils has 10% off at the minute :)
