Engine problem?
Car  RS4 480hp,STI 420hp,ELISE
A new problem for my 182. It happened 2 times this week. I drive at very low speed and the battery and stoplight comes on. Engine stops running.
Can it be due to a broken lambda sensor (light is on since a few weeks)?
Thank you
Difficult word for me :)
Is that he belt from the alternator? That belt was changed a few months ago. I also hear a strange noise sometimes. Can't describe it, but it looks like something has to make a big effort to do his job. Can't describe it (screaming sound? fwiiiiiiiii) :)
yes the alternator/aircon/power steering/water pump belt = the auxillary belt
sounds like a strange problem!
When I start driving, something is doing fwiiiiiiii. It's comming from the enginebay. When I turn ignition on/off, sometimes I have a knock that I can feel in the pedals.
Do they have to tension the belt after a few hundred miles when changed?
And you can be wright, cause it is when I pull of and especially when I use the steering wheel.
Are you a genius or not? :)
