EPAS
Steering column inc the lower part and ecu from a lower spec clio (either 1.2 or did are the most common ones), an eBay controller such as this https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/142463350168, other kits are available but this one has everything you'll need bar some suitable cable to complete the wiring up of the motor/ecu, you can either re use your original steering rack, remove the high pressure hoses and blank off the ports or use a dci rack (slighty shorter ratio than the 1.2 ones I believe).
You'll then need to address the pas pump on the aux belt, either with an idler or by using a cup alternator setup, assuming you're also removing air con too?
There is plenty of info on here for doing the above but if needed I can talk you through it either through pm's or if you're close to the Forest of Dean I could even walk you through it on mine
Ads
If you remove the PAS pump but want to keep the AC, is it as easy as just using a shorter belt? My PAS is playing up, and this looks a better option than trying to sort the hydraulic system
