Erratic idle
Hi all, ive got a 172 exclusive and i love it to bits but please somebody help me! it idles like a pig when hot, perfect from cold fast idle and everything. No codes showing on clip. Any idea's?:S
  GDI Demo 182, Rsi Spider
sounds like a slight air leak... when its hot the gap will be bigger... so worse idle
check the inlet manifold gaskets.
ant
  yep.
everytime i see this thread..........................
spray some wd 40 (or similar) around the joints... plenum to manifold join, throttle body to plenum
etc etc
little squirts at a time...
these will stall the engine or change the speed if they are drawing in air there...
easy way to check for leaks
