Error Lights
Car  Renaultsport Clio 172
I'm sure this will be covered before but i can find a link
Occationally when stationary in traffic the ABS, ACR and service light come on
when you turn the ignition off and back on they go off, any idea's ?
What's an ACR light mate? Sounds like the brake pedal switch issue though to be honest. Do a search for it mate.
I had same issue. As said above, something to do with the brake pedal switch. Doesn't actually seem to do a harm (ACR=ESP?)
As you said, I switch engine off and back on and no probelms. Even found you can do it on the fly - Into neutral, engine off, back on, into gear!
What Daz said. I have it every now and then with mine, only seems to happen when its cold outside too
I'm sure its the ACR light, i'll take a pic of it next time it happens. Is this a seperate issue to the lights coming on because of something under the passenger seat ?
Again, what's an ACR light? ESP is Electronic Stability Programme.
As for the under-seat issue, that's Airbag and Pretensioners so would bring up the Airbag light and Service light.
My bad .... Its ESP, I was getting confused with the Audi i drive at work
So its the ESP, Service and ABS lights that come one randomly
