ESP disabled??
  Clio 182
Help!!, just changed my front bearings, steering rack, abs rings etc etc.... Started the car with no problems however my ESP no longer works/switches on or off? ive tried the switch inside the cabin with nothing?
The ABS is working correctly and everything else appears fine?
I recently had this fault to find it was my abs ring that was goosed, so i replaced it and then a day later the other side had snapped aswell, so i replaced that too although i had the abs light on aswell as my service light, once changed i could then use my esp but my lights had never gone out as soon as i plugged a mac code reader in it all was fettled and the lights still havent come on around a month later so try that ? maybe just a fault code thats still in the car that needs clearing other than that are you sure youve plugged everything in on the rebuild ?
Thanks......I did have a problem with the ABS rings (new driveshaft came with small 7.5 rings that the sensor couldn't read) but once I put the wider ones back on ABS worked fine. Im sure i put everthing back togther fine and correct.
Does anybody know if there is a fuse/relay for the ESP?, Im thinking I may have to plug it into diagnostics to clear a the fault before it works again??
