Every1 with rear discs on a 16v
  A SHED!
My car has got ABS and Ive bought some black diamond discs for the back.These discs have come without a sensor ring sprocket on the back and we cant get it off the old discs as its all one piece. Renault dont do them at all. So how in the hell do I get these discs to fit properly???????? does any1 know where and if I can buy these sensor rings for press on the new discs?? (L-reg 16v) URGENT!!!! Thanks.
  Clio 190bhp Hybrid
Sensor ring is moulded into the actual disc and hub (1 piece unit). Well it is on my Tarox which I got thinking I had ABS and hadnt.
Id take them back and swap them for the correct discs!
  A SHED!
Yeah ABP motorsport, who I bought them off said that I should heat the old rings off and press onto the new discs???? there would be a high chance of damaging them I wouldve thought? thats if, like you said they even come off??? they said that all their black diamond rear discs come like that for the 16v.Are they talking b****cks or does anyone else have black diamond rear discs on their cars? THEY EVEN SAID THEY CANT FIT THEM????? HOW MAD IS THAT? THEY SUPPLY THE DISCS YET CANT BLOODY FIT THEM THEMSELVES!
  A SHED!
Is there no way getting these abs sensor rings from somewhere other than heating the old ones off and damaging them. Save the hassle of taking them all the way back to crewe.
  Trophy
I had to sweat the old ones off and re-fit them, i could probably get my hands on a set if you make it worth my while!
Mat.
  A SHED!
There are two types of sensor rings for the 16v abs. Can you be sure they are the right ones? if so how much do you want for them? was it hard getting the old ones off without damaging them?
  Clio 190bhp Hybrid
My Tarox have the sensor ring as indents on the actual hub itself. Only found out my car didnt have ABS after I had mounted the new bearing in them. Gonna fit when I can get my rear wheels off (lost locking wheel nut adaptor) and hopefully they will be ok, just not needing the ABS sensor so redundant.
Tarox list the two types on their website, does Black Diamond have a website or have you tried phoning. Surely they could help advise you if they have ABS rear disks available.
  A SHED!
Aggggghhhhh im gonna go insane with these bloody discs.Ive rang up everyone from demon-tweeks to renault to hill power and no one can come up with a solution!!! does anyone know the number for black diamond?
  Trophy
Not sure weather they will be the right ones, got my old ones off easily but they must have been the wrong size cos i had to get 3mm machined off the discs.
Mat.
