Exhaust Gasket- Blowing around the cat.
DrR
Car  VW Golf GTD
I was going to go buy a prospeed, but had a look under my car and the exhaust is mint, so won't bother, but it's blowing around the cat and around where it joins around the rear axle/beam.
Is there a gasket set? Anyone know the part number/price?
Any good Exhaust sealant pastes out there?
cat>manifold joint has a sealing ring. cat>centre section has a steel gasket.
As for the rear try pasting up the old joining sleeve or fit a new one.
it's the cat to centre section, pretty easy to replace? just undue the 2 bolts, wack it in then do up?
I keep changing my zorst ever few months at the mo, keep using the same gaskets :oops: just clean them up with a wire brush and re gunk them with gun gum zorst paste... works a treat. as for the back part, again just coat it with gun gum and leave to dry. sorted :D
Ok thanks everyone :), any idea how much this gasket is?
