Exhaust mount?
  Mk II silver 172
My exhaust seems to keep coming off the rear rubber exhaust mount (mk2 172) as there is only one that holds the exhaust on. Cant see a problem with the mount but seesm to slide about in mount fairly easily and actually pops off and hangs down quite often too. Is this a sign the mount needs replacing or is there likely to be something else causing it to come off. How do you replace the rear mount cos sees to be attached to body and then exhaust slid into it rather than slid onto a mounting joint or anything??
ta paul
ant
  yep.
just do this, will cost no more than £2 from halfords.
