F4R Engines
  Clio Cup Racer
Hi everyone,
How similar are the 182 and 197 F4R engines?
Could you bolt a 197 F4R into a 172/182?
Dave.
Don
  182 & LY Clio 220 ed
If it was that easy, it would have been done loads of times already.
For starters, the 6speed box is larger than the one in the 172/182...
  182/RS2/ Turbo/Mk1
If you take the internals from the 197 F4R and put them into the 172 block, and fit the 197 head, then yes it will fit, but bear in mind that the engine management isnt going to be an easy retrofit and the way the cam timing works is different between the two.
IMHO you would be better off just fitting a set of hotter cams and high comp pistons to the 172 engine, as those are the only significant differences other than the cam timing.
  182/RS2/ Turbo/Mk1
The 197 head and inlets can be fitted with a little bit of work
If you fit a 197 head to a 172 bottom end without also fitting the 197 pistons then you will end up with a compression ratio in the 8s which will be utterly useless unless you plan on turboing it too.
The head castings are machined totally differently, there is much more chamber in the 197 head as they use a much more intrusive piston.
The MWMsport turbo demonstrator has a 197 head on a 172 bottom end for this reason.
