F4R Injector Refurbishment?
Car  Clio
Hi,
Is it possible to get the Clio 182 injectors refurbished and if so by whom and how much?
Weighing up options after it looks as though I have an injector failure based on symptoms and fault code.
Thanks,
Will injector tune fix the solenoid in a dodgy injector? I thought they ultrasonic cleaned and flow checked them?
Good service though. I used them on my impreza.
From memory they'll clean and flow check 4 for about £50 including post. Turn around was a few days. But that was a few years ago.
I agree. From what i understand most failures are due to the solenoid rather than blockages, and i don't think they'll fix that.
Hi all,
Thanks for the replies. It's wide throttle above 5,000 rpm drops it onto three cylinders. Fault code is cylinder 3 misfire. Having had similar symptoms of an injector failure before that's what I reckon it is.
Is it worth it? Take out, send off (or deliver) prob cost more than a new one?
£33 new OE
Hi,
Where from? Can only find them listed at £65 each?
Thanks,
