So hello guys ,
I do have a mk1 clio 1.8 thats burning quite some oil , so i bought a f7r710 engine from a megane with 98.000km. I am in the process of tearing apart the f7r to check that everything is in good condition so i can put it on the clio.
I am in thoughts of doing some weighing of the crankshaft, rods and pistons and also putting some new piston rings as far as the block. I would like also to do some work on the head of the motor such as reprofile cams (or a straight set up if its available) with adjsutable pulleys ,maybe harder valve springs and for the sake of reliability maybe converting it to mechanical lifters. Also since the motor is from the late meganes with egr , i would like to delete it and increase the compression by machining the head since i dont want to put forged pistons .
Whats your thoughts on the project and what power do you believe i could achieve with the above . I am not chasing the biggest number , i just want to build a fresh revy engine (since i really liked how the f7p works) but in the same time squize some more power with simple solutions from the f7r.
Feel free to share your thoughts on that .
