Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Hi,
im hoping to make a false floor in my boot and was wondering how to attach the mdf to the boot floor or walls to stop it sliding an bumping around, or would i just need to make it a tight fit?
I used 18mm for the top and for the sides I used a long piece of pine which looked thick. I only used the pine on three sides as I figured you wouldnt see the rear side so no point!
Also I followed the line of the boot carpet around on the MDF but if you do that you'll see that it wont fit neatly into the corners so take a bit of time in measuring and so forth
